Saltar al contenido principal
Toshiba Satellite L505D-GS6000 Disk Drive Replacement
Qué necesitas
  1. Toshiba Satellite L505D-GS6000 Disk Drive Replacement, Battery: paso 1, imagen 1 de 2 Toshiba Satellite L505D-GS6000 Disk Drive Replacement, Battery: paso 1, imagen 2 de 2
    • Shut down the computer and disconnect all cables.
    • Flip the computer over so that the bottom is facing up.
    • Slide right switch above the battery so that it is in the rightwards position.
  2. Toshiba Satellite L505D-GS6000 Disk Drive Replacement: paso 2, imagen 1 de 1
    • Push and hold the left-most switch in the leftward position.
    • While holding the left switch in position, lift up on the battery from the groove in the casing and remove.
  3. Toshiba Satellite L505D-GS6000 Disk Drive Replacement, Disk Drive: paso 3, imagen 1 de 1
    • Remove the M2 5x6 mm screw pointed out in the picture using the Phillips #0 screwdriver.
    • You do not need to remove anything else in order to take out the disk drive.
  4. Toshiba Satellite L505D-GS6000 Disk Drive Replacement: paso 4, imagen 1 de 1
    • Gently slide the disk drive out to the right until it is removed from the computer.
    • If the disk drive doesn’t easily slide out then there is possible damage on the inside of the laptop.
Conclusión
Una persona más ha completado esta guía.
Adam Dellicker
Miembro Desde 03/19/18
539 Reputación
4 Guías creadas
Equipo
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 1
Ultimos 30 días: 3
Todo El Tiempo: 349
