Saltar al contenido principal
Repara tus cosas
Derecho a reparar
Tienda
Introducción
Charging your laptop is necessary for everyday use. However, a faulty power jack can prevent a laptop battery from maintaining a proper charge and even charging at all. This guide will help you find and remove the power jack properly so it can be replaced.
  1. Open the laptop and locate the plastic strip just above the keyboard. With care, slide the prying tool into an end and lift it up until you hear an audible click, meaning it has separated. Slowly slide a finger or the prying tool under and follow the  strip to the opposite end, completely detaching the strip.
    • Open the laptop and locate the plastic strip just above the keyboard.
    • With care, slide the prying tool into an end and lift it up until you hear an audible click, meaning it has separated.
    • Slowly slide a finger or the prying tool under and follow the strip to the opposite end, completely detaching the strip.
  2. Remove the four screws using the Phillips #1 screwdriver. Remove the four screws using the Phillips #1 screwdriver.
    • Remove the four screws using the Phillips #1 screwdriver.
  3. Gently push the clip back as you lift the top of the keyboard towards you. There is a cable connecting the keyboard to the motherboard so do not lift the keyboard all the way out yet.
    • Gently push the clip back as you lift the top of the keyboard towards you.
    • There is a cable connecting the keyboard to the motherboard so do not lift the keyboard all the way out yet.
  4. Gently disconnect the connector strip by pushing the white clips forward. Carefully pull the strip out of its port. Remove the keyboard from the device.
    • Gently disconnect the connector strip by pushing the white clips forward.
    • Carefully pull the strip out of its port.
    • Remove the keyboard from the device.
  5. Turn the laptop upside down. Remove the screw labeled F4 using the Phillips #1 screwdriver.
    • Turn the laptop upside down.
    • Remove the screw labeled F4 using the Phillips #1 screwdriver.
    • There are 2 screws labeled F4, the correct screw is the one closer to the hard drive.
  6. Gently slide the optical drive out of the device. Gently slide the optical drive out of the device.
    • Gently slide the optical drive out of the device.
  7. Turn your laptop upside down, at the bottom of the laptop, slide the right sliding lock to the unlocked position.
    • Turn your laptop upside down, at the bottom of the laptop, slide the right sliding lock to the unlocked position.
    • Slide the left sliding lock to the left and hold it. Using your fingers lift the battery out.
  8. Unscrew all of the screws marked on the underside of the laptop. Remove the screw marked in the second photo by lifting up the lid and unscrewing using a Phillips #1 screwdriver. Remove the three flat screws in the port where the Optical drive is housed in.
    • Unscrew all of the screws marked on the underside of the laptop.
    • Remove the screw marked in the second photo by lifting up the lid and unscrewing using a Phillips #1 screwdriver.
    • Remove the three flat screws in the port where the Optical drive is housed in.
  9. Remove the keyboard and once that has been done, remove the screw marked "16." Disconnect all of the cables with a blue circle.
    • Remove the keyboard and once that has been done, remove the screw marked "16."
    • Disconnect all of the cables with a blue circle.
  10. Using the opening tool, carefully go around the edge and loosen the palm-rest assembly, until you can comfortably and easily lift it off. Using the opening tool, carefully go around the edge and loosen the palm-rest assembly, until you can comfortably and easily lift it off. Using the opening tool, carefully go around the edge and loosen the palm-rest assembly, until you can comfortably and easily lift it off.
    • Using the opening tool, carefully go around the edge and loosen the palm-rest assembly, until you can comfortably and easily lift it off.
  11. Once the motherboard is exposed, gently unplug the power cord from the motherboard. Once the motherboard is exposed, gently unplug the power cord from the motherboard.
    • Once the motherboard is exposed, gently unplug the power cord from the motherboard.
  12. Follow the cable to the  power jack port and carefully lift up to remove it from the laptop.
    • Follow the cable to the power jack port and carefully lift up to remove it from the laptop.
Conclusión
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 2
Ultimos 7 días: 5
Ultimos 30 días: 16
Todo El Tiempo: 446
