Saltar al contenido principal
Toshiba Satellite L505 Laptop Keyboard Replacement
Qué necesitas
  1. Toshiba Satellite L505 Laptop Keyboard Replacement, Keyboard: paso 1, imagen 1 de 3 Toshiba Satellite L505 Laptop Keyboard Replacement, Keyboard: paso 1, imagen 2 de 3 Toshiba Satellite L505 Laptop Keyboard Replacement, Keyboard: paso 1, imagen 3 de 3
    • Open the laptop and locate the plastic strip just above the keyboard.
    • With care, slide the prying tool into an end and lift it up until you hear an audible click, meaning it has separated.
    • Slowly slide a finger or the prying tool under and follow the strip to the opposite end, completely detaching the strip.
  2. Toshiba Satellite L505 Laptop Keyboard Replacement: paso 2, imagen 1 de 2 Toshiba Satellite L505 Laptop Keyboard Replacement: paso 2, imagen 2 de 2
    • Remove the four screws using the Phillips #1 screwdriver.
  3. Toshiba Satellite L505 Laptop Keyboard Replacement: paso 3, imagen 1 de 2 Toshiba Satellite L505 Laptop Keyboard Replacement: paso 3, imagen 2 de 2
    • Gently push the clip back as you lift the top of the keyboard towards you.
    • There is a cable connecting the keyboard to the motherboard so do not lift the keyboard all the way out yet.
  4. Toshiba Satellite L505 Laptop Keyboard Replacement: paso 4, imagen 1 de 3 Toshiba Satellite L505 Laptop Keyboard Replacement: paso 4, imagen 2 de 3 Toshiba Satellite L505 Laptop Keyboard Replacement: paso 4, imagen 3 de 3
    • Gently disconnect the connector strip by pushing the white clips forward.
    • Carefully pull the strip out of its port.
    • Remove the keyboard from the device.
Conclusión
Una persona más ha completado esta guía.
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 9
Ultimos 30 días: 21
Todo El Tiempo: 1,197
