Introducción
The wifi card enables the computer to be compatible with wifi. If the card is malfunctioning, the computer will not receive a signal from any wifi sources. This guide shows how to remove the wifi card so it can be replaced.
Qué necesitas
Unscrew the Phillips #1 4mm screw from the middle panel using a Phillips #1 screwdriver.
4 personas más completaron esta guía.
Un comentario
Wonder if I did change the Wi-Fi card and it stil doesn't work
