Saltar al contenido principal
Toshiba Satellite L455D-S5976 CPU Replacement
Qué necesitas
  1. Toshiba Satellite L455D-S5976 CPU Replacement, Battery: paso 1, imagen 1 de 1
    • Unlock the right tab by sliding it to the right with your finger.
  2. Toshiba Satellite L455D-S5976 CPU Replacement: paso 2, imagen 1 de 1
    • Hold the left tab to the left using your left hand.
  3. Toshiba Satellite L455D-S5976 CPU Replacement: paso 3, imagen 1 de 1
    • Remove the battery by placing your finger in the middle groove and lifting up.
  4. Toshiba Satellite L455D-S5976 CPU Replacement, Optical Drive: paso 4, imagen 1 de 1
    • Remove the 13 Phillips #1 10mm screws from the backside of your computer using a Phillips #1 screwdriver.
  5. Toshiba Satellite L455D-S5976 CPU Replacement: paso 5, imagen 1 de 1
    • Remove the two Phillips #1 6mm screws from the backside of your computer using a Phillips #1 screwdriver.
  6. Toshiba Satellite L455D-S5976 CPU Replacement: paso 6, imagen 1 de 1
    • Remove the three 3mm screws from beneath the battery with a Phillips #1 screwdriver.
  7. Toshiba Satellite L455D-S5976 CPU Replacement: paso 7, imagen 1 de 1
    • Lift up the corner panel and remove it with your hand.
  8. Toshiba Satellite L455D-S5976 CPU Replacement: paso 8, imagen 1 de 1
    • Unscrew the four Phillips #1 3mm using a Phillips #1 screwdriver.
    • Unscrew the four 10mm screws around hard drive using a Phillips #1 screwdriver.
  9. Toshiba Satellite L455D-S5976 CPU Replacement: paso 9, imagen 1 de 2 Toshiba Satellite L455D-S5976 CPU Replacement: paso 9, imagen 2 de 2
    • To remove the hard drive case, first pull the black tab to the right.
    • Then pull the black tab up to remove the case.
  10. Toshiba Satellite L455D-S5976 CPU Replacement: paso 10, imagen 1 de 3 Toshiba Satellite L455D-S5976 CPU Replacement: paso 10, imagen 2 de 3 Toshiba Satellite L455D-S5976 CPU Replacement: paso 10, imagen 3 de 3
    • Remove the plastic strip above the "F" keys using the spudger by placing the small end of the spudger under the strip and lifting up.
  11. Toshiba Satellite L455D-S5976 CPU Replacement: paso 11, imagen 1 de 1
    • Remove the two Phillips #1 3mm screws underneath the plastic strip using a Phillips #1 screwdriver.
  12. Toshiba Satellite L455D-S5976 CPU Replacement: paso 12, imagen 1 de 1
    • Lift the keyboard up and remove it with your hands.
  13. Toshiba Satellite L455D-S5976 CPU Replacement: paso 13, imagen 1 de 1
    • Remove the five Phillips #1 10mm screws underneath the keyboard using a Phillips #1 screwdriver.
  14. Toshiba Satellite L455D-S5976 CPU Replacement: paso 14, imagen 1 de 3 Toshiba Satellite L455D-S5976 CPU Replacement: paso 14, imagen 2 de 3 Toshiba Satellite L455D-S5976 CPU Replacement: paso 14, imagen 3 de 3
    • Lift up the plastic panel and carefully disconnect the red and white ports.
    • Remove the panel
  15. Toshiba Satellite L455D-S5976 CPU Replacement: paso 15, imagen 1 de 1
    • Turn the laptop over so the bottom is facing up
    • Then remove the 3mm screw with a #1 screwdriver, located underneath the panel containing the wifi card and RAM
  16. Toshiba Satellite L455D-S5976 CPU Replacement: paso 16, imagen 1 de 1
    • Turn the laptop back over so the motherboard is facing up
    • Now slide the optical drive out of the computer by gently pulling it to the right
  17. Toshiba Satellite L455D-S5976 CPU Replacement, CPU: paso 17, imagen 1 de 1
    • Remove the two Phillips #1 3mm screws from the fan using a Phillips #1 screwdriver.
  18. Toshiba Satellite L455D-S5976 CPU Replacement: paso 18, imagen 1 de 1
    • Remove the two cables from the fan.
  19. Toshiba Satellite L455D-S5976 CPU Replacement: paso 19, imagen 1 de 2 Toshiba Satellite L455D-S5976 CPU Replacement: paso 19, imagen 2 de 2
    • LIft up on the fan and remove it from the computer.
  20. Toshiba Satellite L455D-S5976 CPU Replacement: paso 20, imagen 1 de 1
    • Remove the six 6mm screws from the motherboard with a #1 phillips screwdriver.
  21. Toshiba Satellite L455D-S5976 CPU Replacement: paso 21, imagen 1 de 1
    • Remove the lone 10mm screw from the motherboard with a phillips #1 screwdriver.
  22. Toshiba Satellite L455D-S5976 CPU Replacement: paso 22, imagen 1 de 2 Toshiba Satellite L455D-S5976 CPU Replacement: paso 22, imagen 2 de 2
    • Remove the motherboard with your hands by carefully lifting up and pulling out.
  23. Toshiba Satellite L455D-S5976 CPU Replacement: paso 23, imagen 1 de 2 Toshiba Satellite L455D-S5976 CPU Replacement: paso 23, imagen 2 de 2
    • Remove the four Phillips #1 6mm single coil pickup screws from the cooling unit and remove the cooling unit.
  24. Toshiba Satellite L455D-S5976 CPU Replacement: paso 24, imagen 1 de 2 Toshiba Satellite L455D-S5976 CPU Replacement: paso 24, imagen 2 de 2
    • Using a flathead screwdriver, undo the lock on the CPU with a half turn in the counterclockwise direction.
    • Remove the CPU by lifting up on the chip.
Conclusión
11 personas más completaron esta guía.
NateJohnson
Miembro Desde 01/26/14
1,047 Reputación
5 Guías creadas
Equipo
Cal Poly, Team 9-26, Maness Winter 2014 Miembro de Cal Poly, Team 9-26, Maness Winter 2014
CPSU-MANESS-W14S9G26
4 Miembros
5 Guías creadas
Un comentario
Just be vary careful with unplugging any connectors. one false step and you could wind up with some more problems.
harh027213 - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 11
Ultimos 30 días: 14
Todo El Tiempo: 3,837
