Introducción
Before starting any removal or installation, remember to turn off the device and to remove it from the power source.
Qué necesitas
Use the flat edge of the plastic opening tool to pry open the narrow plastic strip above the keyboard.
Flip the laptop over to access the battery.
Remove the battery by sliding fingers away from each other and lifting up the tab at the same time.
Remove the following with a Phillips #00 Screwdriver:
Six 7mm Phillips Head screws
One 5 mm Phillips Head screw
Remove the LCD screen tab
Una persona más ha completado esta guía.
