Saltar al contenido principal
Repara tus cosas
Derecho a reparar
Partes y herramientas
Introducción
This guide explains how to replace the RAM in Toshiba Satellite L455-S5046.
Partes
No se especificaron partes.
  1. Remove the Phillips #0 7-mm screw from the back of the computer.
    • Remove the Phillips #0 7-mm screw from the back of the computer.
  2. Kit de Destornilladores Manta
    112 bits for every fix.
    Upgrade Your Toolbox
  3. Remove the plate to access the RAM stick. Remove the plate to access the RAM stick.
    • Remove the plate to access the RAM stick.
  4. Unplug the existing RAM stick. Plug the new RAM stick into the open slot.
    • Unplug the existing RAM stick.
    • Plug the new RAM stick into the open slot.
Conclusión
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 4
Todo El Tiempo: 111
