Saltar al contenido principal
Toshiba Satellite L455-S5046 Keyboard Replacement
Qué necesitas
  1. Toshiba Satellite L455-S5046 Keyboard Replacement, Keyboard: paso 1, imagen 1 de 3 Toshiba Satellite L455-S5046 Keyboard Replacement, Keyboard: paso 1, imagen 2 de 3 Toshiba Satellite L455-S5046 Keyboard Replacement, Keyboard: paso 1, imagen 3 de 3
    • Lift the plastic strip above the keyboard. If you use a lever to pick up the left edge it should pop off.
    • Use the Phillips #0 screwdriver to remove the two indicated 5-mm screws.
  2. Toshiba Satellite L455-S5046 Keyboard Replacement: paso 2, imagen 1 de 2 Toshiba Satellite L455-S5046 Keyboard Replacement: paso 2, imagen 2 de 2
    • Remove the keyboard slowly. It will be attached to the laptop by a plastic connector, which can be disconnected from the laptop by pulling gently.
Conclusión
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 3
Ultimos 30 días: 13
Todo El Tiempo: 391
