Saltar al contenido principal
Toshiba Satellite L35-S2174 Screen Replacement
Qué necesitas
  1. Toshiba Satellite L35-S2174 Screen Replacement, Battery: paso 1, imagen 1 de 1
    • Turn the laptop off to prevent the possibility of electric shock or damage to the computer.
    • Flip the laptop so that the bottom is facing upwards.
  2. Toshiba Satellite L35-S2174 Screen Replacement: paso 2, imagen 1 de 2 Toshiba Satellite L35-S2174 Screen Replacement: paso 2, imagen 2 de 2
    • Slide the battery lock switch to the left.
  3. Toshiba Satellite L35-S2174 Screen Replacement: paso 3, imagen 1 de 2 Toshiba Satellite L35-S2174 Screen Replacement: paso 3, imagen 2 de 2
    • Pull the sliding switch to the right and continue to hold it in this position.
  4. Toshiba Satellite L35-S2174 Screen Replacement: paso 4, imagen 1 de 1
    • While holding the switch, slide the battery away from you.
    • You do not need to hold the switch when putting the battery back into the laptop.
  5. Toshiba Satellite L35-S2174 Screen Replacement, Keyboard: paso 5, imagen 1 de 2 Toshiba Satellite L35-S2174 Screen Replacement, Keyboard: paso 5, imagen 2 de 2
    • Remove the two circled 4mm screws with a J1 screwdriver.
  6. Toshiba Satellite L35-S2174 Screen Replacement: paso 6, imagen 1 de 2 Toshiba Satellite L35-S2174 Screen Replacement: paso 6, imagen 2 de 2
    • Remove the two circled 5mm screws with a J1 screwdriver.
  7. Toshiba Satellite L35-S2174 Screen Replacement: paso 7, imagen 1 de 2 Toshiba Satellite L35-S2174 Screen Replacement: paso 7, imagen 2 de 2
    • Use a spudger to pry up the plastic panel between the keyboard the screen.
    • Repeat on opposite side of laptop.
    • The panel may be difficult to remove.
    • Tilt the laptop's screen back.
    • Lift the panel and remove it from the laptop.
  8. Toshiba Satellite L35-S2174 Screen Replacement: paso 8, imagen 1 de 2 Toshiba Satellite L35-S2174 Screen Replacement: paso 8, imagen 2 de 2
    • There is a ribbon cable underneath the keyboard. Don't lift the keyboard too forcefully or you may break the ribbon cable.
    • Unclip the keyboard from the laptop by lifting it.
    • Slide the keyboard slightly towards the screen.
    • Lift the keyboard out of the way.
  9. Toshiba Satellite L35-S2174 Screen Replacement: paso 9, imagen 1 de 1
    • Pull the ribbon cable straight out of the connector.
    • To reinstall the cable, hold it near the end and push it straight into the connector, being careful not to kink the cable.
  10. Toshiba Satellite L35-S2174 Screen Replacement, Screen: paso 10, imagen 1 de 2 Toshiba Satellite L35-S2174 Screen Replacement, Screen: paso 10, imagen 2 de 2
  11. Toshiba Satellite L35-S2174 Screen Replacement: paso 11, imagen 1 de 2 Toshiba Satellite L35-S2174 Screen Replacement: paso 11, imagen 2 de 2
    • Unscrew the two circled screws with a J1 screwdriver. The screws will remain attached to the plastic panel.
  12. Toshiba Satellite L35-S2174 Screen Replacement: paso 12, imagen 1 de 3 Toshiba Satellite L35-S2174 Screen Replacement: paso 12, imagen 2 de 3 Toshiba Satellite L35-S2174 Screen Replacement: paso 12, imagen 3 de 3
    • Gently lift and detach the grey and black antennae cables that are attached to the blue circuitboard.
    • To reinstall, hold the connectors in place and gently press them straight down. The connectors “snap” into their sockets much like the metal snaps on a jacket.
  13. Toshiba Satellite L35-S2174 Screen Replacement: paso 13, imagen 1 de 1
    • Flip the laptop over.
    • Pull the black and grey cables out of the laptop, towards the laptop screen.
    • The cables are connected to the screen.
  14. Toshiba Satellite L35-S2174 Screen Replacement: paso 14, imagen 1 de 2 Toshiba Satellite L35-S2174 Screen Replacement: paso 14, imagen 2 de 2
    • Detach the black cable from the computer by pulling it to the right.
  15. Toshiba Satellite L35-S2174 Screen Replacement: paso 15, imagen 1 de 1
    • Lift the screen away from the laptop.
Conclusión
Amani Mitchell
Miembro Desde 10/18/16
401 Reputación
4 Guías creadas
Equipo
UMass Dartmouth, Team 1-4, Catania Fall 2016 Miembro de UMass Dartmouth, Team 1-4, Catania Fall 2016
UMASSD-CATANIA-F16S1G4
3 Miembros
5 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 2
Ultimos 7 días: 7
Ultimos 30 días: 14
Todo El Tiempo: 380
