Introducción
In order to take the motherboard cover off the keyboard needs to be removed.
Herramientas
Partes
No se especificaron partes.
Locate the plastic strip at the top of the keyboard.
Use a pry tool to remove the plastic strip.
Using your hands pull out the rest of the plastic strip.
Remove all 6.75mm screws from the bottom of the laptop. The 3 screws under the battery are 3.75mm.
Remove all 5.25mm screws from the top of the laptop.
Casi Terminas!
Conclusión
