Saltar al contenido principal
Repara tus cosas
Derecho a reparar
Tienda
Partes
No se especificaron partes.
  1. Locate the two sliding battery locks on the underside of the laptop.
    • Locate the two sliding battery locks on the underside of the laptop.
  2. Locate the right battery lock and slide it to the right. Locate the right battery lock and slide it to the right.
    • Locate the right battery lock and slide it to the right.
  3. While holding the left battery lock to the left, lift up the battery using the tab located on the top center of the battery. While holding the left battery lock to the left, lift up the battery using the tab located on the top center of the battery.
    • While holding the left battery lock to the left, lift up the battery using the tab located on the top center of the battery.
  4. Remove the battery from the laptop.
    • Remove the battery from the laptop.
  5. Locate the plastic strip at the top of the keyboard. Use a pry tool to remove the plastic strip.
    • Locate the plastic strip at the top of the keyboard.
    • Use a pry tool to remove the plastic strip.
    • Using your hands pull out the rest of the plastic strip.
  6. Use a phillips head #0 screwdriver to remove the two  3.75mm screws holding the keyboard in place.
    • Use a phillips head #0 screwdriver to remove the two 3.75mm screws holding the keyboard in place.
  7. Lift up the top of the keyboard to remove it. Under the keyboard there is a ribbon cable connecting the keyboard to the laptop. Do not just quickly pull out the keyboard. Unlock the ribbon cable by pushing on the locks that are located on both sides of ribbon cable.
    • Lift up the top of the keyboard to remove it.
    • Under the keyboard there is a ribbon cable connecting the keyboard to the laptop. Do not just quickly pull out the keyboard.
    • Unlock the ribbon cable by pushing on the locks that are located on both sides of ribbon cable.
    • Unplug the ribbon cable from the laptop.
  8. Remove the keyboard completely from the laptop.
    • Remove the keyboard completely from the laptop.
Conclusión
William
Miembro Desde 26/03/14
869 Reputación
7 Guías creadas
Equipo
Clemson, Team 1-2, Benson Spring 2014 Miembro de Clemson, Team 1-2, Benson Spring 2014
CLEM-BENSON-S14S1G2
3 Miembros
10 Guías creadas
I have a Toshiba Satellite L305D. A glass of tea was spilled on it several months ago and I just turned it on and it is working but some of the keys do not work, shift, letter a and several more. If I replace the keyboard will this fix this problem or are there more parts that should be replaced? Thanks, Pam
pamtinkle - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 5
Todo El Tiempo: 431
