Saltar al contenido principal
Toshiba Satellite L305D-S5950 Keyboard Replacement
Qué necesitas
  1. Toshiba Satellite L305D-S5950 Keyboard Replacement, Battery: paso 1, imagen 1 de 1
    • Locate the two sliding battery locks on the underside of the laptop.
  2. Toshiba Satellite L305D-S5950 Keyboard Replacement: paso 2, imagen 1 de 2 Toshiba Satellite L305D-S5950 Keyboard Replacement: paso 2, imagen 2 de 2
    • Locate the right battery lock and slide it to the right.
  3. Toshiba Satellite L305D-S5950 Keyboard Replacement: paso 3, imagen 1 de 2 Toshiba Satellite L305D-S5950 Keyboard Replacement: paso 3, imagen 2 de 2
    • While holding the left battery lock to the left, lift up the battery using the tab located on the top center of the battery.
  4. Toshiba Satellite L305D-S5950 Keyboard Replacement: paso 4, imagen 1 de 1
    • Remove the battery from the laptop.
  5. Toshiba Satellite L305D-S5950 Keyboard Replacement, Keyboard: paso 5, imagen 1 de 2 Toshiba Satellite L305D-S5950 Keyboard Replacement, Keyboard: paso 5, imagen 2 de 2
    • Locate the plastic strip at the top of the keyboard.
    • Use a pry tool to remove the plastic strip.
    • Using your hands pull out the rest of the plastic strip.
  6. Toshiba Satellite L305D-S5950 Keyboard Replacement: paso 6, imagen 1 de 1
    • Use a phillips head #0 screwdriver to remove the two 3.75mm screws holding the keyboard in place.
  7. Toshiba Satellite L305D-S5950 Keyboard Replacement: paso 7, imagen 1 de 3 Toshiba Satellite L305D-S5950 Keyboard Replacement: paso 7, imagen 2 de 3 Toshiba Satellite L305D-S5950 Keyboard Replacement: paso 7, imagen 3 de 3
    • Lift up the top of the keyboard to remove it.
    • Under the keyboard there is a ribbon cable connecting the keyboard to the laptop. Do not just quickly pull out the keyboard.
    • Unlock the ribbon cable by pushing on the locks that are located on both sides of ribbon cable.
    • Unplug the ribbon cable from the laptop.
  8. Toshiba Satellite L305D-S5950 Keyboard Replacement: paso 8, imagen 1 de 1
    • Remove the keyboard completely from the laptop.
Conclusión
William
Miembro Desde 03/26/14
875 Reputación
7 Guías creadas
Equipo
Clemson, Team 1-2, Benson Spring 2014 Miembro de Clemson, Team 1-2, Benson Spring 2014
CLEM-BENSON-S14S1G2
3 Miembros
10 Guías creadas
Un comentario
I have a Toshiba Satellite L305D. A glass of tea was spilled on it several months ago and I just turned it on and it is working but some of the keys do not work, shift, letter a and several more. If I replace the keyboard will this fix this problem or are there more parts that should be replaced? Thanks, Pam
pamtinkle - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 1
Todo El Tiempo: 516
