Saltar al contenido principal
Partes
No se especificaron partes.
  1. Locate the two sliding battery locks on the underside of the laptop.
    • Locate the two sliding battery locks on the underside of the laptop.
  2. Locate the right battery lock and slide it to the right. Locate the right battery lock and slide it to the right.
    • Locate the right battery lock and slide it to the right.
  3. While holding the left battery lock to the left, lift up the battery using the tab located on the top center of the battery. While holding the left battery lock to the left, lift up the battery using the tab located on the top center of the battery.
    • While holding the left battery lock to the left, lift up the battery using the tab located on the top center of the battery.
  4. Baterías para ordenadores portátiles
    Un pequeño arreglo para un gran resultado.
    Comprar Ahora
    Comprar Ahora
  5. Remove the battery from the laptop.
    • Remove the battery from the laptop.
  6. Locate the RAM cover on the underside of the laptop.
    • Locate the RAM cover on the underside of the laptop.
  7. Use a phillips head #0 screwdriver to remove the screw located on the RAM cover.
    • Use a phillips head #0 screwdriver to remove the screw located on the RAM cover.
  8. Using your fingers, carefully remove the cover. Using your fingers, carefully remove the cover.
    • Using your fingers, carefully remove the cover.
Conclusión
William
Miembro Desde 26/03/14
863 Reputación
7 Guías creadas
Equipo
Clemson, Team 1-2, Benson Spring 2014 Miembro de Clemson, Team 1-2, Benson Spring 2014
CLEM-BENSON-S14S1G2
3 Miembros
10 Guías creadas
Agregar Comentario
Ver Estadísticas:
Ultimas 24 Horas: 0
Últimos 7 Días: 0
Últimos 30 Días: 1
Todo El Tiempo: 180
