Introducción
This guide will show you how to replace the RAM in the Toshiba Satellite L305D-S5895. Before you begin, you should make sure that the laptop is powered off, and the battery is removed.
Qué necesitas
You will use your P0 screwdriver attachment to undo this screw.
Undo the screw using the screwdriver.
To reassemble your device, follow these instructions in reverse order. Make sure that you have the RAM stick in the correct orientation when attempting to put it back in place.
