Saltar al contenido principal
Toshiba Satellite L305-S5955 Wireless Card Replacement
Qué necesitas
  1. Toshiba Satellite L305-S5955 Wireless Card Replacement, Lock Tabs: paso 1, imagen 1 de 1
    • Slide the lock tabs outward. The right tab will lock into place, but the left tab must be held in place.
  2. Toshiba Satellite L305-S5955 Wireless Card Replacement: paso 2, imagen 1 de 1
    • When you hear a click, lift up and pull out the battery.
  3. Toshiba Satellite L305-S5955 Wireless Card Replacement, Keyboard: paso 3, imagen 1 de 1
    • Use a plastic opening tool to lift out keyboard lining portion located at the top of the keyboard.
  4. Toshiba Satellite L305-S5955 Wireless Card Replacement: paso 4, imagen 1 de 2 Toshiba Satellite L305-S5955 Wireless Card Replacement: paso 4, imagen 2 de 2
    • Remove the 3.6 mm Phillips head PH000 screws securing the keyboard.
  5. Toshiba Satellite L305-S5955 Wireless Card Replacement: paso 5, imagen 1 de 1
    • Use plastic opening tool to pry out the keyboard, starting by the 'delete' key in the top right corner.
  6. Toshiba Satellite L305-S5955 Wireless Card Replacement: paso 6, imagen 1 de 2 Toshiba Satellite L305-S5955 Wireless Card Replacement: paso 6, imagen 2 de 2
    • Lift the keyboard up and locate the ribbon.
    • Gently pull the ribbon out of its compartment to release it from the motherboard.
  7. Toshiba Satellite L305-S5955 Wireless Card Replacement, Wireless Card: paso 7, imagen 1 de 3 Toshiba Satellite L305-S5955 Wireless Card Replacement, Wireless Card: paso 7, imagen 2 de 3 Toshiba Satellite L305-S5955 Wireless Card Replacement, Wireless Card: paso 7, imagen 3 de 3
    • Detach white and black wires by gently pulling straight up.
  8. Toshiba Satellite L305-S5955 Wireless Card Replacement: paso 8, imagen 1 de 1
    • Unscrew both 3 mm Phillips head PH1 screws and allow the wireless card to pop up.
  9. Toshiba Satellite L305-S5955 Wireless Card Replacement: paso 9, imagen 1 de 1
    • Pull the card out vertically.
Conclusión
Samuel Baker
Miembro Desde 01/30/17
307 Reputación
3 Guías creadas
Equipo
IUPUI, Team 1-2, Baechle Spring 2017 Miembro de IUPUI, Team 1-2, Baechle Spring 2017
IUPUI-BAECHLE-S17S1G2
4 Miembros
3 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 2
Ultimos 7 días: 3
Ultimos 30 días: 14
Todo El Tiempo: 791
