Saltar al contenido principal
Toshiba Satellite L305-S5955 Keyboard Replacement
Qué necesitas
  1. Toshiba Satellite L305-S5955 Keyboard Replacement, Lock Tabs: paso 1, imagen 1 de 1
    • Slide the lock tabs outward. The right tab will lock into place, but the left tab must be held in place.
  2. Toshiba Satellite L305-S5955 Keyboard Replacement: paso 2, imagen 1 de 1
    • When you hear a click, lift up and pull out the battery.
  3. Toshiba Satellite L305-S5955 Keyboard Replacement, Keyboard: paso 3, imagen 1 de 1
    • Use a plastic opening tool to lift out keyboard lining portion located at the top of the keyboard.
  4. Toshiba Satellite L305-S5955 Keyboard Replacement: paso 4, imagen 1 de 2 Toshiba Satellite L305-S5955 Keyboard Replacement: paso 4, imagen 2 de 2
    • Remove the 3.6 mm Phillips head PH000 screws securing the keyboard.
  5. Toshiba Satellite L305-S5955 Keyboard Replacement: paso 5, imagen 1 de 1
    • Use plastic opening tool to pry out the keyboard, starting by the 'delete' key in the top right corner.
  6. Toshiba Satellite L305-S5955 Keyboard Replacement: paso 6, imagen 1 de 2 Toshiba Satellite L305-S5955 Keyboard Replacement: paso 6, imagen 2 de 2
    • Lift the keyboard up and locate the ribbon.
    • Gently pull the ribbon out of its compartment to release it from the motherboard.
Conclusión
2 personas más completaron esta guía.
Chris
Miembro Desde 09/30/14
1 Reputación
1 Guía escrita
Equipo
Ohio State, Team 1-2, Buehl Fall 2014 Miembro de Ohio State, Team 1-2, Buehl Fall 2014
OSU-BUEHL-F14S1G2
Miembros de 4
3 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 10
Ultimos 30 días: 13
Todo El Tiempo: 968
