Introducción
Use this guide to replace a faulty power jack in your Toshiba Satellite L305-S5946, which is usually indicated by the computer failing to charge. You must remove the base housing in order to reach the power jack.
Partes
No se especificaron partes.
Loosen the two captive screws on the bottom left corner of the hard drive using a Phillips #1 screwdriver until you hear a click.
Using a Phillips #1 screwdriver, turn the screw on the RAM cover until you hear a click.
Place the laptop upside-down with the display hinges facing away from you.
For the following steps, use a Phillips #1 screwdriver.
Remove the twelve 6-mm screws that border the bottom of the laptop.
Remove the 6-mm screw located in the lower middle of the device.
Remove the three 3-mm screws located in the battery bay.
Remove the one 4-mm screw located near the RAM.
Flip over your laptop so that it is right-side up.
Open your laptop so that the screen faces you.
9 personas más completaron esta guía.
