Introducción
Use this guide to remove housing on the base of your Toshiba Satellite L305-S5946. Removing the housing gives you access to the motherboard, processor, power jack, fan, and LCD screen.
Herramientas
Partes
No se especificaron partes.
Turn the laptop upside-down.
Position the laptop so that the display hinges are facing away from you.
Use a Phillips #1 screwdriver to loosen the two screws on the bottom left-hand side of the hard drive cover.
Turn each screw until you hear a click.
Use a Phillips #1 screwdriver to turn the screw on the RAM cover.
Turn the screw until you hear a click.
Turn the laptop right-side up.
Lift open the laptop so that the screen faces you.
Use a Phillips #1 screwdriver to remove the twelve 6-mm screws that borders the bottom of the laptop.
Use a Phillips #1 screwdriver to remove a 6-mm screw that is located in the lower middle, as shown.
Use a Phillips #1 screwdriver to remove the three 3-mm screws located in the battery bay.
Use a Phillips #1 screwdriver to remove the one 4-mm screw located near the RAM.
Una persona más ha completado esta guía.
