Introducción
If the speakers of your Toshiba Satellite L305-S5875 laptop lose their sound quality or stop working, it is possible to replace them.
In step 6, it is possible to strip the threading on certain screw holes if the screws are not fully removed before the computer cover is removed.
Before you begin this repair, turn off your laptop and unplug it from the charger.
Qué necesitas
Close the laptop lid and flip the laptop over.
Switch the lock button on the left to the unlock position. (The unlock position is to the left side.)
Open the laptop so the keyboard is facing you.
Using your fingers, remove the thin plastic cover above the keyboard.
Close the laptop and flip it over onto its back.
Remove the eleven 6.6 mm Phillips #00 screws along the perimeter and in the center of the laptop.
To reassemble your device, follow these instructions in reverse order. Take your e-waste to an R2 or e-Stewards certified recycler.
