Introducción
This guide demonstrates how to remove a Toshiba Satellite L15W-B1208X hard drive. Reasons the hard drive might need replacing include the hard drive making noise, not running as fast as you would like, or not as much storage as you would like. Before removing the hard drive make sure that it has been backed up so information stored on it is not lost.
Qué necesitas
Use Phillips #1 screwdriver (PH1 bit) to remove the 2mm screw that secures the sound board.
Pull up on the ribbon beneath the hard drive to lift the hard drive upwards.
Una persona más ha completado esta guía.
