Introducción
This is a quick guide on how to replace the RAM of the Toshiba Satellite E45t-B4204. Replacing the RAM helps with speed and processing multiple tasks.
Qué necesitas
Remove all 14 of the 4 mm screws on the back side of the laptop with a Phillips #1 screwdriver.
Locate the RAM. The RAM will be covered by a black protective plastic. Once it is located, the protective plastic will be lifted up exposing the RAM.
Casi Terminas!
Conclusión
