Saltar al contenido principal
Toshiba Satellite CL-15t-t-B1204X Battery Replacement
Qué necesitas
  1. Toshiba Satellite CL-15t-t-B1204X Battery Replacement, Battery: paso 1, imagen 1 de 1
    • Flip the laptop over so the bottom of the device is facing upward.
  2. Toshiba Satellite CL-15t-t-B1204X Battery Replacement: paso 2, imagen 1 de 1
    • Unscrew the 10 5mm Phillips screws, located on the bottom side of the notebook using the PH1 bit and the Magnetic Driver.
  3. Toshiba Satellite CL-15t-t-B1204X Battery Replacement: paso 3, imagen 1 de 1
    • Pry open the bottom cover of the notebook with the plastic spudger tools. Slide a thin tool along the edges without ports to pop open the latches.
    • Be careful not to bend or crack the plastic back cover.
  4. Toshiba Satellite CL-15t-t-B1204X Battery Replacement: paso 4, imagen 1 de 1
    • Remove the 1" yellow tape on top of the battery. This piece of tape is holding down the battery connection cable.
  5. Toshiba Satellite CL-15t-t-B1204X Battery Replacement: paso 5, imagen 1 de 1
    • Lightly grip the battery on the two longest sides. Gently pull up until the adhesive on the notebook is separated from the battery.
  6. Toshiba Satellite CL-15t-t-B1204X Battery Replacement: paso 6, imagen 1 de 1
    • Carefully unplug the battery from the device motherboard.
Conclusión
2 personas más completaron esta guía.
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 2
Ultimos 30 días: 14
Todo El Tiempo: 667
