Introducción
This guide will show you how to replace your Toshiba's DVD tray when it is no longer working correctly.
Qué necesitas
Remove the 7mm Phillips screw located on the back panel of the device using the J1S Phillips head screwdriver.
Remove the ten 7mm screws located on the bottom of the laptop using the J1S screwdriver.
Casi Terminas!
Conclusión
