Introducción
Sometimes a faulty wireless card causes network connection issues, and replacing the card should alleviate them. You’ll need to remove the keyboard as a prerequisite, requiring a PH0-head screwdriver, a rigid pry-tool, and some gentle care needed when opening the ZIF connector. The rest of the process is fairly simple.
Qué necesitas
Flip the laptop over, so that the "top" of the laptop is against your working surface.
Orient the laptop so that the silver label is in the bottom-left corner, with the battery facing you.
Underneath the keyboard, gently disconnect the black and white wires on the right of the wireless adapter using a thin plastic spudger.
