Saltar al contenido principal
Introducción
Typical Toshiba and no service manuals available. The LCD on this laptop was removed for other purposes. This is a straight forward task and only requires minimal tools.
Partes
No se especificaron partes.
  1. Here is the Toshiba Satellite C655D-S5200 Open the laptop with the LCD facing forward. There are four rubber caps, one in each corner Removing the plugs reveal the Phillips screws
    • Here is the Toshiba Satellite C655D-S5200
    • Open the laptop with the LCD facing forward. There are four rubber caps, one in each corner
    • Removing the plugs reveal the Phillips screws
  2. Remove all four screws, tow on top left and right corner One on the bottom left corner and the bottom right corner.
    • Remove all four screws, tow on top left and right corner
    • One on the bottom left corner
    • and the bottom right corner.
    • Here are the four M3x5mm screws
  3. Use a plastic opening tool, or similar to pop the bezel of the LCD assembly Continue to slide the tool all the way across the top Once the bezel has been released from the tabs, it can be further released be applying some gently manual pulling
    • Use a plastic opening tool, or similar to pop the bezel of the LCD assembly
    • Continue to slide the tool all the way across the top
    • Once the bezel has been released from the tabs, it can be further released be applying some gently manual pulling
  4. Continue to pull gently on the sides and finally on the bottom. With all the tabs released the bezel can now be removed.
    • Continue to pull gently on the sides
    • and finally on the bottom.
    • With all the tabs released the bezel can now be removed.
  5. Here is the LCD assembly without the bezel Remove the Phillips screw that connects the LCD frame to the back cover. This is the left one Remove the right one as well
    • Here is the LCD assembly without the bezel
    • Remove the Phillips screw that connects the LCD frame to the back cover. This is the left one
    • Remove the right one as well
  6. The LCD can now be moved forward and away from the rear cover There are three screws on either side that hold the panel to the frame. Remove those Here are the three M2x4 screws
    • The LCD can now be moved forward and away from the rear cover
    • There are three screws on either side that hold the panel to the frame. Remove those
    • Here are the three M2x4 screws
  7. Remove the three Phillips screws on the right side as well. with the screws removed the panel can now be moved out of the LCD frame. The LCD is still connected by the display cable. The display cable is secured to the connector with some clear adhesive. Remove this frist
    • Remove the three Phillips screws on the right side as well.
    • with the screws removed the panel can now be moved out of the LCD frame. The LCD is still connected by the display cable.
    • The display cable is secured to the connector with some clear adhesive. Remove this frist
  8. Remove the display cable carefully. With the display cable disconnected, the LCD can now be removed and replaced.
    • Remove the display cable carefully.
    • With the display cable disconnected, the LCD can now be removed and replaced.
Conclusión
Una persona más ha completado esta guía.
oldturkey03
Miembro Desde 29/09/10
677,459 Reputación
107 Guías creadas
Equipo
Restart Project Miembro de Restart Project
Community
11 Miembros
216 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 2
Ultimos 30 días: 4
Todo El Tiempo: 1,356
