Introducción
This is a guide on how to remove a LCd screen from 15" Toshiba Satellite Laptop. Model # C655-S5212
Qué necesitas
First remove the stickers covers the screws in the 4 corners of LCD case. Stickers are very thin and using utility knife is easiest way to remove without damaging them. After removing stickers unscrew top 2 screws then proceed to Step 2 before trying to remove bottom 2 screws.
Remove 2 screws at bottom of LCD frame and also the 2 screws at top of LCD frame (not pictured). This will allow you to lay the back cover away from frame to access side easier and remove the 3 screws on each side to detach LCD screen. Do not pull LCD once unscrewed, lay down face down on keyboard for last step.
10 personas más completaron esta guía.
2 comentarios
Aoa sir....where to buy a new lcd screen for toshiba core i3??? Plz tell me
I usually get mine from Amazon or Ebay. On the back of LCD there is a sticker with the model number
