Introducción
If the laptop is having internal software issues or Windows has warned that the battery has reached extremely low capacity, use this guide to remove and replace the battery.
Partes
No se requieren partes.
  1. Turn off your laptop before starting. Flip the laptop over so the model stickers face the ceiling.
    • Turn off your laptop before starting.
    • Flip the laptop over so the model stickers face the ceiling.
  2. ¡Envío gratuito para todos los pedidos de más de USD100 o que contengan un Pro Tech Toolkit!
    Visita Nuestra Tienda
  3. Remove the two 7 mm Phillips screws holding the battery using the PH1 bit and Magnetic Driver. Remove the two 7 mm Phillips screws holding the battery using the PH1 bit and Magnetic Driver. Remove the two 7 mm Phillips screws holding the battery using the PH1 bit and Magnetic Driver.
    • Remove the two 7 mm Phillips screws holding the battery using the PH1 bit and Magnetic Driver.
  4. Carefully slide the battery out of the laptop. Carefully slide the battery out of the laptop.
    • Carefully slide the battery out of the laptop.
Conclusión
Ver Estadísticas:
Ultimas 24 Horas: 1
Últimos 7 Días: 3
Últimos 30 Días: 19
Todo El Tiempo: 276
