Introducción
If your Toshiba Satellite C55D-A5108 keyboard is defective in some manner, use this guide to replace it. Before proceeding, check to make sure the keyboard issue is being caused by software instead of the keyboard itself. If you do not feel confident with replacing the keyboard yourself please find someone that can help you with the process.
Qué necesitas
Open the device so that the keyboard is visible.
Slip the wide tip of the spudger underneath the Enter key on the keyboard.
