Saltar al contenido principal
Repara tus cosas
Derecho a reparar
Tienda
  1. Push the left tab with your left hand. Then push the right tab with your right hand. While your right hand is still pushing, remove the battery with your left hand.
    • Push the left tab with your left hand.
    • Then push the right tab with your right hand.
    • While your right hand is still pushing, remove the battery with your left hand.
  2. Remove this screw with a JIS #000 screwdriver. This screw does not come out all the way.
    • Remove this screw with a JIS #000 screwdriver.
    • This screw does not come out all the way.
  3. Remove the panel with the plastic opening tool. Make sure you lift it on all four sides.
    • Remove the panel with the plastic opening tool. Make sure you lift it on all four sides.
  4. Using the JIS #000 screwdriver, remove the .5mm screw. Using the JIS #000 screwdriver, remove the .5mm screw.
    • Using the JIS #000 screwdriver, remove the .5mm screw.
  5. Use the plastic opening tool to remove the keyboard from the laptop. Use the plastic opening tool to remove the keyboard from the laptop.
    • Use the plastic opening tool to remove the keyboard from the laptop.
  6. Once keyboard is popped out, use a nylon spudger to undo the ribbon or flap that attaches the back of the keyboard to the inside base of the laptop. Once keyboard is popped out, use a nylon spudger to undo the ribbon or flap that attaches the back of the keyboard to the inside base of the laptop.
    • Once keyboard is popped out, use a nylon spudger to undo the ribbon or flap that attaches the back of the keyboard to the inside base of the laptop.
Conclusión
3 personas más completaron esta guía.
Step has the incorrect screw to release the keyboard. There is no need to open the back panel. The screw which holds down the keyboard is the long screw between the Serial Number sticker and the battery release switch #2.
Anthony Francisco - Contestar
Agreed 100%. Good thing I looked at this comment before I ran into major trouble. Thank you!
Jeff Breuer -
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 7
Ultimos 30 días: 30
Todo El Tiempo: 1,523
