Introducción
These are the steps for removing the webcam from your Toshiba Satellite C55-B5302 laptop. Since the webcam is delicate in nature and has photosensitive parts, you should be careful when handling the webcam unit and make sure not to scratch the lens or expose it to bright light for too long.
Qué necesitas
Remove the remaining 7 mm screws on the back panel of the laptop with a Phillips #0 screwdriver.
Use the plastic opening tool to pry up a corner of the back panel and continue to pop the back panel off.
After the fan has been removed, lift the hinge so as to get access to the parts below it.
Remove the the black colored cable that is now exposed.
Remove the three 4.1 mm Phillips #0 screws attaching each hinge to the screen.
2 personas más completaron esta guía.
