Introducción
Before starting this process you will need to remove the battery and take off the cover. It's easier than it looks and only requires a Phillips #0 screwdriver and a plastic opening tool. Expect to take about 10 minutes for this process from start to finish.
Qué necesitas
Remove the remaining 7 mm screws on the back panel of the laptop with a Phillips #0 screwdriver.
Use the plastic opening tool to pry up a corner of the back panel and continue to pop the back panel off.
3 personas más completaron esta guía.
