Saltar al contenido principal
Toshiba Satellite C55-B5200 Keyboard Replacement
Qué necesitas
  1. Toshiba Satellite C55-B5200 Keyboard Replacement, Battery: paso 1, imagen 1 de 1
    • Turn the laptop off and remove all sources of power.
    • Flip the laptop over so that way the bottom is facing towards you.
    • Remove the two 6.6mm Phillips #0 screws from the battery.
  2. Toshiba Satellite C55-B5200 Keyboard Replacement: paso 2, imagen 1 de 1
    • Pull the battery out of the laptop.
  3. Toshiba Satellite C55-B5200 Keyboard Replacement, Keyboard: paso 3, imagen 1 de 1
    • Remove the thirteen 6.6mm Phillips #0 screws on the back of the device.
  4. Toshiba Satellite C55-B5200 Keyboard Replacement: paso 4, imagen 1 de 1
    • Use a plastic opening tool to lift and remove the bottom panel.
  5. Toshiba Satellite C55-B5200 Keyboard Replacement: paso 5, imagen 1 de 1
    • Remove the six 2.3mm Phillips #0 screws from the motherboard.
    • Use a pair of tweezers to lift up the tab on the ZIF connector and pull out the ribbon cable.
  6. Toshiba Satellite C55-B5200 Keyboard Replacement: paso 6, imagen 1 de 3 Toshiba Satellite C55-B5200 Keyboard Replacement: paso 6, imagen 2 de 3 Toshiba Satellite C55-B5200 Keyboard Replacement: paso 6, imagen 3 de 3
    • Disconnect the wires from the motherboard.
    • Lift and remove the disk drive.
    • Lift and remove the hard drive.
  7. Toshiba Satellite C55-B5200 Keyboard Replacement: paso 7, imagen 1 de 1
    • Lift up the motherboard
    • Use tweezers to carefully peel apart IDE ribbon cables connected from motherboard to keyboard
  8. Toshiba Satellite C55-B5200 Keyboard Replacement: paso 8, imagen 1 de 2 Toshiba Satellite C55-B5200 Keyboard Replacement: paso 8, imagen 2 de 2
    • Use a plastic opening tool to unlatch the keyboard from the device
    • Lift the keyboard off the laptop, careful of the IDE ribbon cable
Conclusión
2 personas más completaron esta guía.
Pablo Andrade
Miembro Desde 02/14/18
1,081 Reputación
7 Guías creadas
Equipo
USF Tampa, Team S3-G1, Nance Spring 2018 Miembro de USF Tampa, Team S3-G1, Nance Spring 2018
USFT-NANCE-S18S3G1
4 Miembros
22 Guías creadas
Un comentario
gracias por la guía
Mark Puga - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 12
Ultimos 30 días: 32
Todo El Tiempo: 3,750
