Saltar al contenido principal
Toshiba Satellite C55-B5200 Hard Disk Drive Replacement
Qué necesitas
  1. Toshiba Satellite C55-B5200 Hard Disk Drive Replacement, Battery: paso 1, imagen 1 de 1
    • Turn the laptop off and remove all sources of power.
    • Flip the laptop over so that way the bottom is facing towards you.
    • Remove the two 6.6mm Phillips #0 screws from the battery.
  2. Toshiba Satellite C55-B5200 Hard Disk Drive Replacement: paso 2, imagen 1 de 1
    • Pull the battery out of the laptop.
  3. Toshiba Satellite C55-B5200 Hard Disk Drive Replacement, Hard Disk Drive: paso 3, imagen 1 de 3 Toshiba Satellite C55-B5200 Hard Disk Drive Replacement, Hard Disk Drive: paso 3, imagen 2 de 3 Toshiba Satellite C55-B5200 Hard Disk Drive Replacement, Hard Disk Drive: paso 3, imagen 3 de 3
    • Remove the two 4.6mm Phillips #0 screws from disk drive.
    • Lift the disk drive and pull out to remove.
Conclusión
5 personas más completaron esta guía.
Pablo Andrade
Miembro Desde 02/14/18
1,081 Reputación
7 Guías creadas
Equipo
USF Tampa, Team S3-G1, Nance Spring 2018 Miembro de USF Tampa, Team S3-G1, Nance Spring 2018
USFT-NANCE-S18S3G1
4 Miembros
22 Guías creadas
Un comentario
Pablo, you didn’t mention that you must remove all the screws to get at the hard drive. What a pain. Other satellites have compartments the c55 that i have you must take every screw out as the back is one piece. Thanks for the instructions.
stevesd619 - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 2
Ultimos 30 días: 12
Todo El Tiempo: 4,474
