Introducción
A guide on how to replace the fan on your Toshiba Satellite C55-B5200 laptop.
Herramientas
Partes
No se especificaron partes.
Turn the laptop off and remove all sources of power.
Flip the laptop over so that way the bottom is facing towards you.
Remove the two 6.6mm Phillips #0 screws from the battery.
Remove the single 4.6mm Phillips #0 screw securing the fan.
Use a pair of tweezers to unplug the fan from the motherboard.
Pull the fan out.
Una persona más ha completado esta guía.
