Saltar al contenido principal
Introducción
Replacing the optical drive in a Toshiba Satellite laptop should not be seen as difficult, but does involve opening one of the panels on the underside of the laptop.
Partes
No se especificaron partes.
  1. Press down with your fingers while also applying a sliding motion on the latch buttons near the battery on the underside of your laptop.
    • Press down with your fingers while also applying a sliding motion on the latch buttons near the battery on the underside of your laptop.
  2. Lift the battery upward with your fingers out of the battery compartment.
    • Lift the battery upward with your fingers out of the battery compartment.
  3. Place laptop with the bottom of it facing up. Remove the single 6mm Phillips #1 screw keeping the laptop panels in place. Remove the single 6mm Phillips #1 screw keeping the laptop panels in place.
    • Place laptop with the bottom of it facing up.
    • Remove the single 6mm Phillips #1 screw keeping the laptop panels in place.
  4. Remove the 4mm Phillips #1 screw on the side of the now exposed area.
    • Remove the 4mm Phillips #1 screw on the side of the now exposed area.
  5. Remove the disc drive from the device.
    • Remove the disc drive from the device.
Conclusión
2 personas más completaron esta guía.
Un Comentario
Any idea of how tall the drive is? Is it 12.7mm or 9.5mm tall?
Luis Alejandro Araúz - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 4
Todo El Tiempo: 189
