Introducción
Here, using a Phillips screwdriver, and a plastic opening tool, you will learn how to clean the fan in your computer.
Partes
No se requieren partes.
  1. Click button 1 to the unlocked position.
    • Click button 1 to the unlocked position.
    • This button will have a 1 by it.
  2. Push and hold button 2 to the left. As you push button 2 to the left position, simultaneously lift up the battery pack.
    • Push and hold button 2 to the left.
    • As you push button 2 to the left position, simultaneously lift up the battery pack.
    • This button will have a 2 by it.
  3. Using the Phillips #1 screwdriver, remove the eleven 2.5mm screws. Using the Phillips #1 screwdriver, remove the eleven 2.5mm screws.
    • Using the Phillips #1 screwdriver, remove the eleven 2.5mm screws.
  4. ¡Envío gratuito para todos los pedidos de más de USD100 o que contengan un Pro Tech Toolkit!
    Visita Nuestra Tienda
  5. Remove the one 2.5mm Phillips #1 middle plate screw.
    • Remove the one 2.5mm Phillips #1 middle plate screw.
  6. Lift up the middle vent panel.
    • Lift up the middle vent panel.
    • Set the panel to the side.
  7. Using the plastic opening tool, remove the outer panel and set to the side. Be careful not to break the back of the computer. Be careful not to break the back of the computer.
    • Using the plastic opening tool, remove the outer panel and set to the side.
    • Be careful not to break the back of the computer.
  8. Using a Phillips #1 screwdriver, remove the one 1.5mm screw. Using a Phillips #1 screwdriver, remove the one 1.5mm screw. Using a Phillips #1 screwdriver, remove the one 1.5mm screw.
    • Using a Phillips #1 screwdriver, remove the one 1.5mm screw.
  9. Lift the fan up and blow compressed air or replace with a new one.
    • Lift the fan up and blow compressed air or replace with a new one.
    • Blow compressed air into the spirals in the middle of the fan.
Conclusión
Ver Estadísticas:
Ultimas 24 Horas: 1
Últimos 7 Días: 1
Últimos 30 Días: 13
Todo El Tiempo: 146
