Saltar al contenido principal
Toshiba Satellite A85-S107 15" Keyboard Replacement
Qué necesitas
  1. Toshiba Satellite A85-S107 15" Keyboard Replacement, Battery: paso 1, imagen 1 de 1
    • Power off the laptop.
    • Disconnect the power cable from the laptop. If you do not, electric shock may result.
  2. Toshiba Satellite A85-S107 15" Keyboard Replacement: paso 2, imagen 1 de 1
    • Flip the laptop over and orient it such that the battery faces towards you and the front faces away from you as shown in the diagram.
    • Unlock the battery by sliding the tab shown to the right
    • This tab will latch into place.
  3. Toshiba Satellite A85-S107 15" Keyboard Replacement: paso 3, imagen 1 de 2 Toshiba Satellite A85-S107 15" Keyboard Replacement: paso 3, imagen 2 de 2
    • Slide the tab shown to the left and remain holding it.
    • This tab does not lock into place like in the first step.
    • Place your thumb on the grips of the battery as shown.
    • While holding onto the grips, pull the battery towards you and away from the laptop.
  4. Toshiba Satellite A85-S107 15" Keyboard Replacement, Keyboard: paso 4, imagen 1 de 1
    • Flip the laptop over so that the front tab of the laptop faces you.
  5. Toshiba Satellite A85-S107 15" Keyboard Replacement: paso 5, imagen 1 de 3 Toshiba Satellite A85-S107 15" Keyboard Replacement: paso 5, imagen 2 de 3 Toshiba Satellite A85-S107 15" Keyboard Replacement: paso 5, imagen 3 de 3
    • Unlock the laptop by sliding the front tab to the right.
    • Open the laptop by lifting the screen up while holding the tab in place.
  6. Toshiba Satellite A85-S107 15" Keyboard Replacement: paso 6, imagen 1 de 3 Toshiba Satellite A85-S107 15" Keyboard Replacement: paso 6, imagen 2 de 3 Toshiba Satellite A85-S107 15" Keyboard Replacement: paso 6, imagen 3 de 3
    • Place the laptop on its left side with the disk drive facing up and the screen open completely.
    • Locate the rectangular slot on the side of the laptop just above the disk drive.
    • Insert the flat end of the spudger into the rectangular slot.
  7. Toshiba Satellite A85-S107 15" Keyboard Replacement: paso 7, imagen 1 de 2 Toshiba Satellite A85-S107 15" Keyboard Replacement: paso 7, imagen 2 de 2
    • Insert the opening tool into the rectangular slot with the spudger.
    • Pry off the top part of the laptop's case (above the keyboard) containing the speakers by using both the spudger and opening tool to push the case away from the computer.
    • Once the top part of the laptop's case has been popped off, use your hands to remove it.
  8. Toshiba Satellite A85-S107 15" Keyboard Replacement: paso 8, imagen 1 de 1
    • Place the laptop on a level surface with the keyboard facing you.
  9. Toshiba Satellite A85-S107 15" Keyboard Replacement: paso 9, imagen 1 de 1
    • Remove the two 5mm Phillips #1 screws which hold the keyboard in place.
  10. Toshiba Satellite A85-S107 15" Keyboard Replacement: paso 10, imagen 1 de 1
    • Unhook the plastic tab at the top of the keyboard using the plastic opening tool to pry the top of the keyboard up.
  11. Toshiba Satellite A85-S107 15" Keyboard Replacement: paso 11, imagen 1 de 2 Toshiba Satellite A85-S107 15" Keyboard Replacement: paso 11, imagen 2 de 2
    • Lift up the keyboard from the back end where the function keys are located.
    • Slide the keyboard out towards the screen.
    • Be careful not to rip the ribbon out of its port.
    • This may damage your laptop.
  12. Toshiba Satellite A85-S107 15" Keyboard Replacement: paso 12, imagen 1 de 1
    • Pull the ribbon wire attaching the keyboard to the computer out of its port.
    • Before you pull try to hold the ribbon wire as close to the port as possible to prevent it from breaking.
Conclusión
Alana
Miembro Desde 04/14/13
96 Reputación
3 Guías creadas
Equipo
Cal Poly, Team 10-38, Amido Spring 2013 Miembro de Cal Poly, Team 10-38, Amido Spring 2013
CPSU-AMIDO-S13S10G38
4 Miembros
24 Guías creadas
Un comentario
This absolutely one of the best help guides I have ever used.
Lenny - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 4
Ultimos 30 días: 5
Todo El Tiempo: 961
