Saltar al contenido principal
Repara tus cosas
Derecho a reparar
Partes y herramientas
Introducción
Use this guide to replace or install the disc drive in your Toshiba laptop.
Partes
No se especificaron partes.
  1. Power off the laptop.
    • Power off the laptop.
    • Disconnect the power cable from the laptop. If you do not, electric shock may result.
  2. Flip the laptop over and orient it such that the battery faces towards you and the front faces away from you as shown in the diagram.
    • Flip the laptop over and orient it such that the battery faces towards you and the front faces away from you as shown in the diagram.
    • Unlock the battery by sliding the tab shown to the right
    • This tab will latch into place.
  3. Kit de Destornilladores Manta
    112 bits for every fix.
    Upgrade Your Toolbox
  4. Slide the tab shown to the left and remain holding it. This tab does not lock into place like in the first step.
    • Slide the tab shown to the left and remain holding it.
    • This tab does not lock into place like in the first step.
    • Place your thumb on the grips of the battery as shown.
    • While holding onto the grips, pull the battery towards you and away from the laptop.
  5. Flip the laptop over and orient it so that the battery faces away from you. Remove the 5mm Phillips #0 screw on the bottom case.
    • Flip the laptop over and orient it so that the battery faces away from you.
    • Remove the 5mm Phillips #0 screw on the bottom case.
  6. Insert the plastic opening tool into the gap between the disk drive and the laptop and pop out the disk drive. Slid the disc drive out of its slot on the left side of the computer. It should slide out easily. Slid the disc drive out of its slot on the left side of the computer. It should slide out easily.
    • Insert the plastic opening tool into the gap between the disk drive and the laptop and pop out the disk drive.
    • Slid the disc drive out of its slot on the left side of the computer. It should slide out easily.
Conclusión
Alana
Miembro Desde 14/04/13
96 Reputación
3 Guías creadas
Equipo
Cal Poly, Team 10-38, Amido Spring 2013 Miembro de Cal Poly, Team 10-38, Amido Spring 2013
CPSU-AMIDO-S13S10G38
4 Miembros
8 Guías creadas
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 0
Todo El Tiempo: 381
