Introducción
If your computer is slow, freezes frequently, or displays a blue screen upon starting up, you may need to replace your hard drive. To replace your Toshiba Satellite A665-S5170 hard drive, you will need a Phillips head 0 screwdriver. Remember to treat your hard drive gently when removing it from your computer.
Qué necesitas
Turn the computer upside down so that the bottom of the laptop is facing up.
Using a Phillip’s head 0 screwdriver, remove the 2mm Phillips head screw on the right side of the cover of the hard drive panel by rotating it counter-clockwise.
