Introducción
This guide provides step by step instructions of how to replace a faulty optical drive.
Qué necesitas
Flip the laptop over so the bottom is facing up.
Slide each of the three tabs on the bottom half of the assembly into the unlocked position.
Remove the single 3mm Phillips #00 screw that secures the wireless card cover.
Un comentario
Or, simply remove the screw (the center one in this photo) from the bottom case that holds the bracket in and pull the drive out.
