Saltar al contenido principal
Toshiba Satellite A215-S7425 Hard Drive Replacement
Qué necesitas
  1. Toshiba Satellite A215-S7425 Hard Drive Replacement, Battery: paso 1, imagen 1 de 1
    • Turn off the computer.
    • Disconnect the charging cable from computer.
    • Failure to unplug the cable could result in electric shock.
    • Flip the computer upside down.
  2. Toshiba Satellite A215-S7425 Hard Drive Replacement: paso 2, imagen 1 de 1
    • Slide latches labeled #1 and #2, located outside the battery cover, away from each other.
    • Latch #1 will click over and stay while latch #2 will have to be held for battery to release.
  3. Toshiba Satellite A215-S7425 Hard Drive Replacement: paso 3, imagen 1 de 1
    • Gently lift and pull the battery out of the device.
  4. Toshiba Satellite A215-S7425 Hard Drive Replacement, Hard Drive: paso 4, imagen 1 de 2 Toshiba Satellite A215-S7425 Hard Drive Replacement, Hard Drive: paso 4, imagen 2 de 2
    • Locate hard drive cover opposite the battery on the lower left corner of the device.
    • Loosen 2 Phillips 4.2 mm size captive screws from cover.
    • Lift cover slightly from the edge where the screws are and pull slowly out and to the right, releasing it from its latches on the left.
  5. Toshiba Satellite A215-S7425 Hard Drive Replacement: paso 5, imagen 1 de 3 Toshiba Satellite A215-S7425 Hard Drive Replacement: paso 5, imagen 2 de 3 Toshiba Satellite A215-S7425 Hard Drive Replacement: paso 5, imagen 3 de 3
    Herramienta utilizada en este paso:
    Anti-Static Wrist Strap
    $7.95
    • Locate the thin plastic tab folded on right side of hard drive case.
    • Hold plastic tab and gently pull tab slightly up and to the left to remove hard drive case from device.
    • To avoid damage to the hard drive or motherboard connectors; Do not pull plastic tab in a straight up direction.
    • The use of a anti-static wrist strap while working with the hard drive is advise to prevent electrostatic discharge(ESD) from damaging the hard drive.
  6. Toshiba Satellite A215-S7425 Hard Drive Replacement: paso 6, imagen 1 de 1
    • Remove 4 (2 on each side) Phillips 4.1 mm size screws from case.
  7. Toshiba Satellite A215-S7425 Hard Drive Replacement: paso 7, imagen 1 de 1
    • Slide case away from hard drive.
Conclusión
Una persona más ha completado esta guía.
Marianne
Miembro Desde 09/08/14
647 Reputación
6 Guías creadas
Equipo
Pasco Hernando, Team 5-2, Prince Fall 2014 Miembro de Pasco Hernando, Team 5-2, Prince Fall 2014
PHSC-PRINCE-F14S5G2
Miembros de 10
18 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 3
Ultimos 30 días: 31
Todo El Tiempo: 1,015
