Saltar al contenido principal
Toshiba Satellite A215-S4757 Battery Replacement
Qué necesitas
  1. Toshiba Satellite A215-S4757 Battery Replacement, Battery: paso 1, imagen 1 de 1
    • Before removing anything on your Toshiba Satellite, make sure your computer is turned off, and your power adapter is not plugged in.
  2. Toshiba Satellite A215-S4757 Battery Replacement: paso 2, imagen 1 de 1
    • Turn your Satellite over and locate your battery.
    • Locate the battery clips.
    • With your thumb and pointer fingers slide them outward at the same time, and hold.
  3. Toshiba Satellite A215-S4757 Battery Replacement: paso 3, imagen 1 de 2 Toshiba Satellite A215-S4757 Battery Replacement: paso 3, imagen 2 de 2
    • Gently lift the battery out of its socket until completely removed and release the clips.
    • Your battery is now removed from your computer.
Conclusión
2 personas más completaron esta guía.
Jacob Brown
Miembro Desde 10/10/16
409 Reputación
3 Guías creadas
Equipo
Texas Tech, Team 12-2, Bennett Fall 2016 Miembro de Texas Tech, Team 12-2, Bennett Fall 2016
TTU-BENNETT-F16S12G2
4 Miembros
9 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 4
Todo El Tiempo: 286
