Introducción
The optical drive contains both precise lasers and lenses and a powerful motor to read and write disk drives. And we know that precision and fast spinning doesn't go well with each other. But don't worry! If your optical drive is giving you trouble, you can easily replace it with a new one.
Qué necesitas
Close the laptop and turn it over so that the base is facing upwards and the spine is facing away from you.
Find the battery compartment.
Slide the left slider which is just beneath the battery compartment into its leftmost position.
Turn computer over so that the battery compartment is facing up and is at the top.
Locate and unscrew one captive Phillips #1 screw located at the center.
9 personas más completaron esta guía.
