Introducción
In this guide you will learn how to remove the RAM. In the case of a broken or unresponsive RAM a replacement may be required. Before begining this guide you should have all required tools that are listed.
Qué necesitas
Remove the screw holding the RAM cover with a PH1 screwdriver.
Remove the RAM cover.
In order to reassemble your device, follow these instructions in reverse order.
Una persona más ha completado esta guía.
