Saltar al contenido principal
Toshiba Satellite A205-S4577 Battery Replacement
  1. Toshiba Satellite A205-S4577 Battery Replacement, Battery: paso 1, imagen 1 de 1
    • Locate the two sliding locks indicated in the photo.
    • Slide the right lock (labeled "1") to the right. It will remain in the unlocked position.
    • Slide the left lock (labeled "2") to the left and hold it in place.
  2. Toshiba Satellite A205-S4577 Battery Replacement: paso 2, imagen 1 de 1
    • While holding the left lock, place your finger in the indentation next to the battery and lift the battery out.
Conclusión
Equipo
Cal Poly, Team 17-6, Regan Spring 2013 Miembro de Cal Poly, Team 17-6, Regan Spring 2013
CPSU-REGAN-S13S17G6
5 Miembros
33 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 3
Todo El Tiempo: 811
