Saltar al contenido principal
Toshiba Satellite A105-S4284 Trackpad Replacement
Qué necesitas
  1. Toshiba Satellite A105-S4284 Trackpad Replacement, Battery: paso 1, imagen 1 de 2 Toshiba Satellite A105-S4284 Trackpad Replacement, Battery: paso 1, imagen 2 de 2
    • Make sure your computer is turned off and the computer is not plugged in.
    • Turn your laptop upside down, and slide the right release tab outward.
    • Using you left hand, hold the left release tab towards the left side and then pull the battery out.
  2. Toshiba Satellite A105-S4284 Trackpad Replacement, Casing: paso 2, imagen 1 de 3 Toshiba Satellite A105-S4284 Trackpad Replacement, Casing: paso 2, imagen 2 de 3 Toshiba Satellite A105-S4284 Trackpad Replacement, Casing: paso 2, imagen 3 de 3
    • Disconnect wire attaching LCD to motherboard
    • Using the Phillips screwdriver remove the two 4.0mm screws from each hinge above speakers
    • Partially close the lid and remove the last two 4.0mm screws from the back of the laptop.
  3. Toshiba Satellite A105-S4284 Trackpad Replacement: paso 3, imagen 1 de 2 Toshiba Satellite A105-S4284 Trackpad Replacement: paso 3, imagen 2 de 2
    • Remove the seventeen 4.5mm phillips screws on the bottom of the laptop.
    • Using the pry tool separate the two halves of the laptop base.
    • Use caution when separating the laptop halves as they are still connected by two ribbon cables.
  4. Toshiba Satellite A105-S4284 Trackpad Replacement: paso 4, imagen 1 de 2 Toshiba Satellite A105-S4284 Trackpad Replacement: paso 4, imagen 2 de 2
    • Lift the top half of the case enough to get your hand beneath it, and then remove the two ribbon cables that connect it to the motherboard.
  5. Toshiba Satellite A105-S4284 Trackpad Replacement, Trackpad: paso 5, imagen 1 de 1
    • the upper half of the computer base.
  6. Toshiba Satellite A105-S4284 Trackpad Replacement: paso 6, imagen 1 de 2 Toshiba Satellite A105-S4284 Trackpad Replacement: paso 6, imagen 2 de 2
    • Remove the 3 4.5mm screws holding the track-pad in place.
    • There are some screws that will be hidden by assembly tape.
  7. Toshiba Satellite A105-S4284 Trackpad Replacement: paso 7, imagen 1 de 1
    • Slide green circuit board to right and lift track pad free from laptop.
Conclusión
Josh
Miembro Desde 03/12/14
685 Reputación
5 Guías creadas
Equipo
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 5
Ultimos 30 días: 6
Todo El Tiempo: 507
