Saltar al contenido principal
Toshiba Satellite A105-S4284 Keyboard Replacement
Qué necesitas
  1. Toshiba Satellite A105-S4284 Keyboard Replacement, Battery: paso 1, imagen 1 de 2 Toshiba Satellite A105-S4284 Keyboard Replacement, Battery: paso 1, imagen 2 de 2
    • Make sure your computer is turned off and the computer is not plugged in.
    • Turn your laptop upside down, and slide the right release tab outward.
    • Using you left hand, hold the left release tab towards the left side and then pull the battery out.
  2. Toshiba Satellite A105-S4284 Keyboard Replacement, Keyboard: paso 2, imagen 1 de 1
    • Flip the laptop over so it is rightside up, and open the laptop all the way so that the screen is horizontal.
  3. Toshiba Satellite A105-S4284 Keyboard Replacement: paso 3, imagen 1 de 3 Toshiba Satellite A105-S4284 Keyboard Replacement: paso 3, imagen 2 de 3 Toshiba Satellite A105-S4284 Keyboard Replacement: paso 3, imagen 3 de 3
    • Using the plastic opening tool, pry off the panel above the keyboard, starting near the right front speaker.
    • Use the plastic opening tool to pop off tabs along the length of this panel.
    • This may feel like you're about to break something, but as long as you work your way down the panel and don't yank it out, the laptop will be fine.
  4. Toshiba Satellite A105-S4284 Keyboard Replacement: paso 4, imagen 1 de 2 Toshiba Satellite A105-S4284 Keyboard Replacement: paso 4, imagen 2 de 2
    • Unscrew the two 4.5 mm screws holding the keyboard on with the Phillips #1 screwdriver.
  5. Toshiba Satellite A105-S4284 Keyboard Replacement: paso 5, imagen 1 de 3 Toshiba Satellite A105-S4284 Keyboard Replacement: paso 5, imagen 2 de 3 Toshiba Satellite A105-S4284 Keyboard Replacement: paso 5, imagen 3 de 3
    • Lift the keyboard gently from the side closest the screen.
    • Pull out the ribbon connecting the keyboard to the laptop.
Conclusión
Una persona más ha completado esta guía.
pfedigan
Miembro Desde 04/12/13
11 Reputación
4 Guías creadas
Equipo
Cal Poly, Team 2-23, Maness Spring 2013 Miembro de Cal Poly, Team 2-23, Maness Spring 2013
CPSU-MANESS-S13S2G23
4 Miembros
13 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 9
Ultimos 30 días: 16
Todo El Tiempo: 1,511
