Introducción
This guide gives instructions on how to remove the front panel of the Toshiba SD-K740 DVD player, a necessary step to access all parts for repair/replacement.
Partes
No se requieren partes.
  1. Make sure the DVD player is unplugged before beginning.
    • Make sure the DVD player is unplugged before beginning.
    • Remove the three .303 inch screws from the back panel using a #0 Phillips head screwdriver.
  2. Turn the DVD player on its side. Remove the .303 inch screw.
    • Turn the DVD player on its side.
    • Remove the .303 inch screw.
    • Now flip the DVD player onto its other side.
    • Remove the .303 inch screw from this side.
  3. ¡Envío gratuito para todos los pedidos de más de USD100.00 o que contengan un Pro Tech Toolkit!
    Visita Nuestra Tienda
    ¿Alguna vez arreglaste algo? Eso es genial.
    Comparte tu historia de reparación con #SoyUnGenio
    Todos somos Genios
  4. Flip the DVD player over onto it's front face.
    • Flip the DVD player over onto it's front face.
    • Remove the back panel by lifting up and pulling it towards yourself.
  5. Flip the DVD player so its top is sitting on your working surface.
    • Flip the DVD player so its top is sitting on your working surface.
    • Lift and push away each of the two tabs located in the middle of the player.
    • The front panel will not come off during this step, so do not force it.
  6. Flip the DVD player on its side.
    • Flip the DVD player on its side.
    • Lift and slide forward a single tab on the side.
  7. Grasp the front panel and pull forward and to your right to remove. Grasp the front panel and pull forward and to your right to remove.
    • Grasp the front panel and pull forward and to your right to remove.
Conclusión
Joe Murphy
Miembro Desde 20/01/11
542 Reputación
5 Guías creadas
Equipo
Cal Poly, Team 1-16, Amido Winter 2011 Miembro de Cal Poly, Team 1-16, Amido Winter 2011
CPSU-AMIDO-W11S1G16
4 Miembros
8 Guías creadas
Ver Estadísticas:
Ultimas 24 Horas: 0
Últimos 7 Días: 0
Últimos 30 Días: 0
Todo El Tiempo: 403
