Saltar al contenido principal
Introducción
A worn-out belt is not strong enough to open or close disc tray. Belt might be broken.
Herramientas
Partes
  1. Five identical screws: three in back, one in each of left and right sides. Cover lifts away.  One may call it 'top cover'.
    • Five identical screws: three in back, one in each of left and right sides. Cover lifts away. One may call it 'top cover'.
  2. Kits de Reparación de Batería de MacBook Air
    A partir de $69.99
    Buy Now
    A partir de $69.99
    Buy Now
  3. Disc tray being open/extended-out is a precondition to access its drive belt. Use a stick to depress optical deck and unclamp spindle.  As optical deck lowers, disc tray juts.  Pull or push tray toward its out & open position.
    • Disc tray being open/extended-out is a precondition to access its drive belt.
    • Use a stick to depress optical deck and unclamp spindle. As optical deck lowers, disc tray juts. Pull or push tray toward its out & open position.
  4. Replace tray/drive belt.
    • Replace tray/drive belt.
Conclusión
unsubstantiated
Miembro Desde 07/06/16
779 Reputación
4 Guías creadas
Agregar Comentario
Ver Estadísticas:
Ultimas 24 Horas: 0
Últimos 7 Días: 3
Últimos 30 Días: 6
Todo El Tiempo: 68
