Saltar al contenido principal
Toshiba Qosmio X775-3DV80 Keyboard Replacement
Qué necesitas
  1. Toshiba Qosmio X775-3DV80 Keyboard Replacement, Battery: paso 1, imagen 1 de 2 Toshiba Qosmio X775-3DV80 Keyboard Replacement, Battery: paso 1, imagen 2 de 2
    • Turn your laptop over so the underside is facing up.
  2. Toshiba Qosmio X775-3DV80 Keyboard Replacement: paso 2, imagen 1 de 2 Toshiba Qosmio X775-3DV80 Keyboard Replacement: paso 2, imagen 2 de 2
    • Identify the two sliding locks on either side of the battery.
    • Simultaneously slide both locks outward to release the battery.
  3. Toshiba Qosmio X775-3DV80 Keyboard Replacement: paso 3, imagen 1 de 1
    • Pull the battery straight out of its slot to remove it.
  4. Toshiba Qosmio X775-3DV80 Keyboard Replacement, Optical Drive: paso 4, imagen 1 de 1
    • Locate the optical drive retaining screw on the underside of the laptop.
  5. Toshiba Qosmio X775-3DV80 Keyboard Replacement: paso 5, imagen 1 de 1
    • Using a Phillips #00 screwdriver, remove the optical drive retaining screw.
  6. Toshiba Qosmio X775-3DV80 Keyboard Replacement: paso 6, imagen 1 de 2 Toshiba Qosmio X775-3DV80 Keyboard Replacement: paso 6, imagen 2 de 2
    • Using your finger or a spudger, push the optical drive out of its compartment so you can grab it.
    • Pull the optical drive out of its slot in the side of the laptop.
  7. Toshiba Qosmio X775-3DV80 Keyboard Replacement, RAM: paso 7, imagen 1 de 1
    • Loosen the single screw on the service panel by twisting counterclockwise with a Phillips #00 screwdriver.
    • It is a captive screw that will remain attached to the service panel.
  8. Toshiba Qosmio X775-3DV80 Keyboard Replacement: paso 8, imagen 1 de 1
    • Using a spudger or plastic opening tool, pry off the service panel.
  9. Toshiba Qosmio X775-3DV80 Keyboard Replacement: paso 9, imagen 1 de 3 Toshiba Qosmio X775-3DV80 Keyboard Replacement: paso 9, imagen 2 de 3 Toshiba Qosmio X775-3DV80 Keyboard Replacement: paso 9, imagen 3 de 3
    • Using your fingers, pull the retaining clips away from the RAM sticks.
    • Pull the RAM sticks out of the slots.
  10. Toshiba Qosmio X775-3DV80 Keyboard Replacement, Keyboard: paso 10, imagen 1 de 2 Toshiba Qosmio X775-3DV80 Keyboard Replacement, Keyboard: paso 10, imagen 2 de 2
    • Using a Phillips #00 screwdriver, remove all the remaining fourteen screws from the bottom case of the laptop.
    • The service panel should already be removed.
  11. Toshiba Qosmio X775-3DV80 Keyboard Replacement: paso 11, imagen 1 de 2 Toshiba Qosmio X775-3DV80 Keyboard Replacement: paso 11, imagen 2 de 2
    • Using a Phillips #00 screwdriver, remove the five screws under the service panel.
    • Remove the retaining clip.
  12. Toshiba Qosmio X775-3DV80 Keyboard Replacement: paso 12, imagen 1 de 1
    • Using a spudger, pry the keyboard from the top panel of the laptop.
    • Make sure to pry it off all around.
  13. Toshiba Qosmio X775-3DV80 Keyboard Replacement: paso 13, imagen 1 de 3 Toshiba Qosmio X775-3DV80 Keyboard Replacement: paso 13, imagen 2 de 3 Toshiba Qosmio X775-3DV80 Keyboard Replacement: paso 13, imagen 3 de 3
    • Disconnect the two ribbon cables connecting the keyboard to the laptop.
    • Unplug the connector on the bottom of the laptop.
Conclusión
Jesse Adam Ory
Miembro Desde 03/24/19
745 Reputación
7 Guías creadas
Equipo
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 4
Ultimos 30 días: 9
Todo El Tiempo: 477
